if you make it virgin first then yes
bigkey (19th July, 2018)
i have a few used opel/vauxhall remotes
after vvdi renew corsa d only tp working remote not astra H not accepted at all
tehnosoftex (19th July, 2018)
I see on the vvdi prog blog that there are 2 files for 2 types of key for astra h. They say that it will work. I don't have these files.
http://blog.xhorsevvdi.com/vvdi-prog...937-tested-ok/
hemm my local retail shop also gave up the astra h keys renew and chinese clones. Mostly bcose they are not accepted by the cars regardless the programming device.
But try it maybe you have better luck. The eeprom files are linked here in the forum if you don't find it i will send you
Astra h flip work with vvdi prog, corsa d renew successful but didn't try on the car.
Astra-H and Corsa-D keys are different. Renew with VVDIprog works fine
yes i know they are differnt.
But for me the corsa d only the tp part working the remote isn't
The astra H remote not accepted at all. Tomorrow i will test again just for sure
What are you using to renew.......I've done 100's Astra H's never killed one yet & yes all the remote side works prefect
If you get no remote after renew the chip is 7941 (wrong EEprom file)......to renew the corsa D boards the chip must end with the letter B
if only 7941 you will kill the chip
jodge (22nd July, 2018), paul_12345 (20th July, 2018)
ghostrider72 (22nd July, 2018), PocketHero (23rd July, 2018)
