Results 1 to 8 of 8
    Jun 2018
    Default opcom v.145 nightmare help please??
    hi is there any1 that can give me some pointers on getting my opcom scanner to work? using v1.45 and china clone 120309a cant seem to get a response from my ecu tho... astra h 1.9 cdti 150 thanks
    Dunker's Avatar
    Yorkshire
    Have you got comms to the other modules in the car?
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
    Jun 2018
    No not had any response from the car just says initialising ecu and no response...
    Dunker's Avatar
    Yorkshire
    What do you get when you "Test Interface" ?
    You might be better testing it on the bench and scoping data lines for K and CAN.
    Jun 2018
    Checking Interface...
    Disable SWCAN...
    Switched to DWCAN...
    Pin #6,#14 switched to HSCAN...
    also saying no power from car but red and green lights both on...
    Disable SWCAN...
    Pin #6,#14 switched to HSCAN... the most ive had is the ignition lights flashing while checking interface... bit of a novice so not sure what settings etc to go for...any pointers would be much appreciated thanks
    Jun 2018
    Sorry i picked u up wrong there when I test interface its saying successful and v. 145 im using Windows 10 x 64...
    Dunker's Avatar
    Yorkshire
    Dunno about W10. Tried it for a short while and binned it. Total shit for diag stuff. Half the time defender interferes and screws USB comms and u cant switch it off. Try flashing an ecu when defender decides it wants to update half way thu and see what happens.
    W7 x86 or XP (or W7 x64 if u specifically need it) with no AV best for any diag sw especially with opcom 139 145 154. If W7 theres a few bits to disable like UAC, defender, notifications, USB power mode etc. etc.
    Dunno about yr problem tho. Is it just on that car? Have u measured voltage on obd socket and scoped data lines? (pins 6 and 14). If signals there then try another interface. They are cheap enough.
  8. The Following User Says Thank You to Dunker For This Useful Post:
    Meat-Head (17th June, 2018)
  9. #8
    Jun 2018
    Quote Originally Posted by Dunker View Post
    Yeah I see ur point was having to boot up in advanced start up to disable driver signing etc i am gonna try it in my dads vectra also have an older laptop i can dig out an try thanks again
    Sent from my G3311 using Tapatalk
