Results 1 to 14 of 14
    Feb 2018
    Default MFD 2 Radio Decode
    I need the Radio code from this Navigation:
    Blaupunkt GMBH
    7 612 002 065
    7L6 035 191 R
    Thank you
    trn's Avatar
    EU_IT
    read Fis 24C64
  3. The Following User Says Thank You to trn For This Useful Post:
    eFighter (8th June, 2018)
    Feb 2018
    Can you tell me where I can find this chip or the Pinout?
    Jul 2013
    code in FIS read and post dump here
  6. The Following User Says Thank You to petronijul For This Useful Post:
    trn's Avatar
    EU_IT
    try pinout
  8. The Following User Says Thank You to trn For This Useful Post:
  9. #6
    Feb 2018
    Thanks I was able to read the data with Martech. Furthermore I was able to read the code. But the Unit is locked at the moment.
    Can someone tell me which data I have to edit to unlock the unit?
  10. #7
    Oct 2013
    Ukraine
    Quote Originally Posted by eFighter View Post
    Hi. where is your dump?
  11. The Following User Says Thank You to masterskay62 For This Useful Post:
  12. #8
    Feb 2018
    Sorry there is the dump file.
  13. #9
    shooting's Avatar
    WALES
    Your code is 1234
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  14. The Following 3 Users Say Thank You to shooting For This Useful Post:
    eFighter (8th June, 2018), smoggy (8th June, 2018), Thinner (8th June, 2018)
  15. #10
    Feb 2018
    Thanks Martech told me the same code. Do you know which data I have to edit to unlock the unit because at the moment the unit is blocked. Coused by to many wrong codes.
  16. #11
    POLAND
    Thanks I Martech told me the same code. Do you know which data I have to edit to unlock the unit because at the moment the unit is blocked. Coused by to many wrong codes.
    If you use martech, push the "reset counter" button, write to device and comper files beffore and after.
  17. The Following User Says Thank You to voltec For This Useful Post:
  18. #12
    Feb 2018
    I always received a error Message when I try this.
    Could you try the reset my dump file?
  19. #13
    trn's Avatar
    EU_IT
    Martech does not support (FIS) reset counter
    stay on for 60 minutes
    for the reset counter
  20. The Following User Says Thank You to trn For This Useful Post:
  21. #14
    Feb 2018
    Thanks, everything works now perfect.
