No way you will read this dash via OBD. You need to dismantle cluster and read 9s12 motorola by external programmer like Xprog.
And next time post such thread in dashboard / immo or locksmith section
Hello Folks
I recently got a 2008 vw polo with 1 key
have always done my own servicing / repairs and had an old opel astra with opcom for diagnostics
If I wanted to make a new key for the polo my understanding is that I would need the pin code from the instrument cluster
I have picked up a chinese clone vcds for diagnostics ( error codes and the like ).
It says the instrument cluster is
Component:KOMBIINSTRUMENT AGD V04 which I beleive is Magnetti Marelli
Component: IMMOBILIZER AGD V04
What tool would I need to get to read the eeprom in the cluster I have seen vag pro can and K line would this be suitable ?.
and with future proofing in mind if I ever needed to replace the cluster
This car does not appear to be can bus
as both the vcds and the Launch creader connect only in K:line
Thanks for taking the time to read
and any replies much appreciated
gerinemo (16th June, 2018)
