Hello.
The thread was discussed in our forum:
http://www.digital-kaos.co.uk/forums...FVDI-ID-F08151
You try to install FVDI Driver manually:
Please note:
Before installing FVDI software, please close all anti-virus software. Otherwise, you can't install FVDI successfully.
After installing FVDI software, if you can't run the software, generally, it is driver problem.
Please install FVDI driver manually.
How to install FVDI Driver manually?
Go to Program file - Abrites Commander Software List - USB Interface Drivers
After Installing it give error message: mfc110u.dll is missing
After Installing FVDI, if you get this error message: "This application failed to start because mfc110u.dll was not found."
How To Fix Mfc110u.dll Errors
Important: Do not download mfc110u.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of mfc110u.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the mfc110u.dll error.
Download the Visual C++ Redistributable for Visual Studio 2012 Update 4 package and run it. This will replace/restore the mfc110u.dll with the most recent copy provided by Microsoft.You're given several download options from Microsoft for this update, based on the version of Windows you have installed - x86 (32-bit) or x64 (64-bit). See Am I Running a 32-bit or 64-bit Version of Windows? for help if you're not sure what to choose.Important: Try your best to complete this step. Applying this update is almost always the solution to mfc110u.dll errors.
And be sure to see here:
http://blog.uobdii.com/how-to-solve-...6-locked-error
