Can somebody help me is there any problem similiar with mine?
I have problem with this fvdi unit i only have vag soft activated . And from this morning when i start it says device niot opened and red and green lamps on dongle are blinking but there is no green ligjht on device .
Is there any solution it worked fine and didnt go on internet or similiar it just not working anymore what could be a problem ?
Please help mates
Hello
Check the connector from the sofdog and interface. Also check the solder pads at these connectors.
immokill (11th June, 2018)
Look here: http://blog.obdii365.com/2015/11/16/...d-red-light-on. If you have correctly connected and activated and the device does not work, check the solder fields in the FVDI interface.
immokill (12th June, 2018)
Forgive me, but my poor knowledge of English is a problem.
Which version of FVDI do you have? Is this the first launch of FVDI? On which operating system did you install FVDI?
Does the device manager appear in the device manager after connecting FVDI?
Have you read the FAQ at "http://www.fvdiobd.com/fvdi-faq.html".
Install a virtualbox and place Windows XP on it. Then install FVDI and then check. We must rule out the problem of drivers.
In Windows 7, Windows XP mode is not the same as Virtualbox. Please :
1. Download from Virtualbox at: https: //www.virtualbox.org and install on Windows 7.
2. Download the VirtualBox Extension Pack and install .
3. Install Windows XP on Virtualbox.
4. Run Windows XP on a virtual machine.
5. Install the FVDI software on Windows XP.
6. Restart Windows XP.
7. Connect FVDI to the computer.
8. Select the FVDI interface driver in the Virtualbox menu and start the FVDI software.
After connecting fvdi to the computer, a new device should appear in the Virtualbox menu "Devices / USB Devices / VendorID ....", which should be selected for connection.
If you have made these steps correctly, you probably have a faulty FVDI interface. With a certain probability, we can assume that the flash is damaged. If you get the right file (FVDI firmware) for your version of the interface, you can use the free Flashmagic program and the appropriate programmer to program the interface. I am afraid that your interface has committed "harakiri".
I tried to unlock the firmware on my FVDI but with a bad ID .my id is F00705 is the wrong id F08481 FWDownloader F08481.
I have an error the green light flashing red
