Results 1 to 12 of 12
    MRAWZIN's Avatar
    Jan 2016
    tunisie bousid
    Default vcds or vas odis
    hello all mermber dk
    what is the best vcds 18.2 or vas odis 5054a
    (clone from aliexpresse)
    nil's Avatar
    Polska
    Hello
    In my opinion, VAS will be better for learning, but in the case of clones you should buy both VAS and VCDS. How do you say when you work on them, you will be able to
    buy the original. The original VAS will be very expensive, plus fees for online functions they exclude him for amateur applications. Sorry for my English.
  3. The Following 2 Users Say Thank You to nil For This Useful Post:
    Col19 (18th November, 2019), MRAWZIN (11th June, 2018)
    May 2017
    I prefer vcds because you can log your sensors.
    It's a must have for a good chiptuning
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    vcds itīs easier to use, and you will find a lot of tutorial videos on youtube...
    but also without tutorial videos, itīs easy...
    but there are also ecuīs for example airbag units... last week I had a LT 2015... I could read it without issues, but not delete DTC...
    at the end I take VAS out of bag, and VAS + Odis did it...
    my opinion take both, the clones are cheap... VCP is also not bad to have it...
    When I helped you press Thanks and Reputation...
  6. The Following User Says Thank You to figani For This Useful Post:
    Stelaras26 (11th February, 2020)
    Jul 2019
    I would like to understand the memory of ecus, can you indicate sources? The programming language, the reading software and how to do the programming.
  8. #6
    Mar 2019
    vas5054a China clone can support diagnosis, online/offline programming, has more functions than vcds China copy.
  9. #7
    Mar 2013
    GB
    Better to have them both .
    for vas5054a , make sure its not the one from vcx , it must be vas5054 with oki full chip
  10. #8
    Jul 2013
    yorkshire
    Why not just buy vcds original. Full support, free updates for life, not too expensive.
  11. The Following User Says Thank You to autoden For This Useful Post:
  12. #9
    Nov 2017
    vagcom is much faster, but You need to know what to look.
    ODIS haw guided fault find, but it it is painfuly slow, using it when You hav problem.
  13. The Following User Says Thank You to SDIracer For This Useful Post:
  14. #10
    Dec 2019
    Japan
    1. Multi-languages: English/Japanese/Portuguese/Romanian/Korean/Dutch/Polish/Turkish/Spanish/ French/Italian/Croatian/Danish/German/Swedish/Finnish/Slovenian/Czech/Russian/Greek/Chinese
    2. Newest software: V5.16
    3. Update: Update from download weblink
    4. Instead of OEM tool of VAS 5054A
    5. Support UDS Protocol
    6. Supported Car Models: VW, AUDI, SKODA(2001 to 2018)
    7. Support WIFI/USB Connection
  15. #11
    dimitar's Avatar
    Quote Originally Posted by serenakong4328 View Post
    vas5054a China clone can support diagnosis, online/offline programming, has more functions than vcds ORIGINAL.
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  16. #12
    Sep 2018
    Austria
    Has anyone a link to download odis?
