Bdm and problem solved.
Hello friends,
I'm new to flashing and have purchased china MPPS v16. The program gets the ECU ID ok but cannot read the ECU flash (timeout).
My car is 2005 Mk5 Golf 1.6 FSI - BLP engine code
Part No SW: 03C 906 056 AK HW: Hardware No
Component: MED9.5.10 G00 6095
I have tried to take out the instrument cluster fuse (Fuse 6 on dash panel) but still getting error. I am using MPPS v16.1.0.2 without loader on Windows 10 Pro.
Has anyone experienced this and knows how to fix it?
Many thanks for your help.
lemta (13th June, 2018)
bdm the best way or you can with kess v2 5.017 via obd to read and write
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
lemta (14th June, 2018)
Ktag bdm the best way ,if yoy have and china kess 5.017 too can be ok via obd
File Service
29volts is bad interface voltage meansuring
File Service
Has anyone succesfully managed to read VW Golf/Audi A3 1.4/1.6 FSI engine ecu with MPPS? Just wondering whether it's a bad clone or MPPS is not compatible with MED9.5.10 ecu.
Just to UPDATE...
I've given up with this MPPS v16 and ordered a MPPS v13 to see if I have better luck with older hardware. I did consider ordering Kess v2 but since I am only going to use it on just the one car it seems a waste of money really.
Anyway, you'll probably hear from me again saying it doesn't work haha!
Hi, any updates? There were issues that Mpps V13 solved that problem on older ECUs (Like EDC15C3).
Also this "read" problem was solved when Car's Battery was connected to the charger and Voltage across battery terminals was not less than 13VDC.
Just for record I use v16 Chinese cable fine on my 1.6 FSI, just very slow read and write.
Use Windows XP in VirtualBox and pass the cable through
Mpps v18 work good with MED 9.5.10 via obd.
Wysłane z mojego SM-N970F przy użyciu Tapatalka
Attention... if 95080, 95160 or 95320 inside and what K-Tag Protocoll (should be 64 or 108) shows to read .Ktag bdm the best way ,if yoy have and china kess 5.017 too can be ok via obd
Some need some mods in definition for Ktag to read ecu correct way.
