Results 1 to 14 of 14
    Member lemta's Avatar
    Jun 2012
    Default MPPS v16 not reading ECU
    Hello friends,
    I'm new to flashing and have purchased china MPPS v16. The program gets the ECU ID ok but cannot read the ECU flash (timeout).
    My car is 2005 Mk5 Golf 1.6 FSI - BLP engine code
    Part No SW: 03C 906 056 AK HW: Hardware No
    Component: MED9.5.10 G00 6095
    I have tried to take out the instrument cluster fuse (Fuse 6 on dash panel) but still getting error. I am using MPPS v16.1.0.2 without loader on Windows 10 Pro.
    Has anyone experienced this and knows how to fix it?
    Many thanks for your help.
    Jun 2013
    EU
    Bdm and problem solved.
  3. The Following User Says Thank You to morgano For This Useful Post:
    lemta (13th June, 2018)
    Jun 2012
    Quote Originally Posted by morgano View Post
    I am a novice so BDM would be probably bit too much for me having to remove ECU etc. I also do not want to buy extra hardware if possible. Thanks for your advice anyway friend.
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    bdm the best way or you can with kess v2 5.017 via obd to read and write
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  6. The Following User Says Thank You to AVDigitale For This Useful Post:
    lemta (14th June, 2018)
  7. #5
    Jun 2012
    Quote Originally Posted by AVDigitale View Post
    Are you saying it is not possible to read/write using MPPS on Bosch Med9.5.10 even though it says it's supported through OBD2 port? Thank you.
    Also will china clone Kess v2 be ok?
    What about Vag Can Pro will that work on Med9.5.10 through OBD port?
  8. #6
    AVDigitale's Avatar
    Apr 2017
    Ktag bdm the best way ,if yoy have and china kess 5.017 too can be ok via obd
    File Service
  9. The Following User Says Thank You to AVDigitale For This Useful Post:
  10. #7
    raceshadow's Avatar
    Mar 2016
    Czech Republic
    Quote Originally Posted by lemta View Post
    Hello friends,
    29 volts??
    IF I HELPED YOU, PRESS THANKS AND REPUTATION BUTTON!!!
  11. #8
    AVDigitale's Avatar
    Apr 2017
    29volts is bad interface voltage meansuring
    File Service
  12. #9
    Jun 2012
    Has anyone succesfully managed to read VW Golf/Audi A3 1.4/1.6 FSI engine ecu with MPPS? Just wondering whether it's a bad clone or MPPS is not compatible with MED9.5.10 ecu.
  13. #10
    Jun 2012
    Just to UPDATE...
    I've given up with this MPPS v16 and ordered a MPPS v13 to see if I have better luck with older hardware. I did consider ordering Kess v2 but since I am only going to use it on just the one car it seems a waste of money really.
    Anyway, you'll probably hear from me again saying it doesn't work haha!
  14. #11
    Mar 2011
    Hi, any updates? There were issues that Mpps V13 solved that problem on older ECUs (Like EDC15C3).
    Also this "read" problem was solved when Car's Battery was connected to the charger and Voltage across battery terminals was not less than 13VDC.
  15. #12
    Nov 2019
    Just for record I use v16 Chinese cable fine on my 1.6 FSI, just very slow read and write.
    Use Windows XP in VirtualBox and pass the cable through
  16. #13
    May 2018
    Mpps v18 work good with MED 9.5.10 via obd.
    Wysłane z mojego SM-N970F przy użyciu Tapatalka
  17. #14
    May 2017
    Attention... if 95080, 95160 or 95320 inside and what K-Tag Protocoll (should be 64 or 108) shows to read .
    Some need some mods in definition for Ktag to read ecu correct way.
