Results 1 to 2 of 2
    koziolek's Avatar
    Feb 2010
    Under the car
    82
    Downloads
    28
    Uploads
    Default Mini Cooper 2009 Engine Stall During Driving
    Car stall during drive, scan the vehicle no errors.
    Starter crank no problem, car does not start at all, there is fuel pressure, there is injector pulse and there is visible spark on spark plug,compression 180 Psi on all cylinders
    any one has similar problem ?
    Jun 2010
    Europe
    22
    Downloads
    5
    Uploads
    What scan tool did you use? Did you had any errors before you cleared them, or were there no errors to begin with?
    Problem with error codes is that the engine has to run for a couple of seconds before the error code is saved in most cases, especially timing related errors. Check your distribution for timing, it's a common problem.
