toyota camry 2017 89170-06760 need help !!!
Results 1 to 4 of 4
    Feb 2017
    Default toyota camry 2017 89170-06760 need help !!!
    hi all m8 ! pls help me reset srs 89170-06760 toyota camry . MCU is h8sx -1725. thank for anny help
    May 2010
    USA
    write the same "code flash"- back in MCU -that you read!!!
    crash in eeprom area will be erased
  3. The Following User Says Thank You to alexs600 For This Useful Post:
    matik185 (14th March, 2019)
    Mar 2019
    hi
    thanh you
    Brayn's Avatar
    Oct 2015
    Colombo
    Quote Originally Posted by Otocar View Post
    hi
    thanh you
    you should read Main Flash. after write back it then crash will remove. crash have eeprom area when you write main flash eeprom will be erased. MCU is renesas 1725
  6. The Following 3 Users Say Thank You to Brayn For This Useful Post:
    alex2019 (16th September, 2019), matik185 (14th March, 2019), sohrabi (17th March, 2019)
