crafter 2012 key programming
Results 1 to 5 of 5
    Default crafter 2012 key programming
    someone can guide me how to program a key from a crafter 2012?
    van have 2 keys and both you can start the van with but after 1 sec. the engine cut off again. immo problem.
    i have read the ezs and fimd the pin code.
    i have try to relearn the keys with vcds and van start 1 time but when switch the ignition off you get same problem again.
    can i make a key with Tango china?
    i have only vcds and Tango china.
    rob h's Avatar
    May 2011
    Your Keys are fine.
    The problem is most likely elswere
  3. The Following User Says Thank You to rob h For This Useful Post:
    vageric (16th June, 2018)
    Mar 2013
    Europe
    DTC's in ECU?
  5. The Following User Says Thank You to bersch8688 For This Useful Post:
  6. #4
    dtc's were cranckshaft sensor and immo if i remember correct.
    Fallen's Avatar
    I saw a similar problem a while back.
    If you disconnected the battery it would start only once and then stop when it was turned off.
    Repeat to start again.
    Never heard what the problem with it was.
  8. The Following User Says Thank You to Fallen For This Useful Post:
