Page 1 of 3 123 LastLast
Results 1 to 15 of 40
    BigJ's Avatar
    Default Audi Q7 no start/ dash dead/ steering locked after spare key prog
    Hi All.
    Got a Q7, Made spare key with Zed Full, but something went wrong. Original key and new spare key both not working.
    Got a fault in ELV that said somthing like Keys incorrectly coded.
    Cleared all faults, and still not starting.
    Dash shows 1/0 above odometer.
    Cant read ELV by OBD any longer as ignition wont turn on.
    Have pulled out ELV and read dumps from 9S12dg256 with vvdi prog (Attached).
    Can someone please help? (Kinda urgent. You how customers can get)
    J
    PRESS THANKS AND ADD_REP JUST FOR THE HELL OF IT..... PLEASE.....THANK YOU!
    Try to recode just the original key and see if it comes back to life. If you have the pin and cs it should work with a force ignition tool or by jumping fuses
    Sent from my SM-G930W8 using Tapatalk
  3. The Following User Says Thank You to dmp For This Useful Post:
    BigJ (15th June, 2018)
    BigJ's Avatar
    Quote Originally Posted by dmp View Post
    Dont have pin or cs mate
    You can get it from the elv dump
    I can check for you tonight. Will be a while though, hopefully somebody else can help before then
  6. The Following User Says Thank You to dmp For This Useful Post:
    autochei's Avatar
    Mar 2013
    romania
    reset batery.........
    Dump recognized: OK
    Programmed keys: 1
    VIN: WAUZZZ4L87D096742
    PIN: 63594
  8. The Following User Says Thank You to autochei For This Useful Post:
  9. #6
    BigJ's Avatar
    Quote Originally Posted by autochei View Post
    Removed the battery for a while if that wat u mean mate
  10. #7
    autochei's Avatar
    Mar 2013
    romania
    yes remove batery if still not working try co code back with pin code
  11. #8
    BigJ's Avatar
    My soft dont recognise elv dump, so cant pull pin
  12. #9
    autochei's Avatar
    Mar 2013
    romania
    Dump recognized: OK
    Programmed keys: 1
    PIN: 63594
  13. The Following User Says Thank You to autochei For This Useful Post:
  14. #10
    BigJ's Avatar
    Cant pull pin
  15. #11
    BigJ's Avatar
    how the hell did u get that??
    aweesome, thanks mate!
  16. #12
    BigJ's Avatar
    how to code it though if ignition dont switch on?
  17. #13
    autochei's Avatar
    Mar 2013
    romania
    no need strap u have allready pin
    only put vcds vvdi and programing again one key
    ur key it s not precoded ok
    so the car it s in learning mode waitting second key to programing
  18. The Following User Says Thank You to autochei For This Useful Post:
  19. #14
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    VCDS? Are you drunk Marius?
    AVDI ONLY for this.
  20. The Following User Says Thank You to lupu_sandu For This Useful Post:
  21. #15
    BigJ's Avatar
    ok gonna give it a go with vvdi quickly.....
    fingers crossed
