Write another flash from 9s12 256 and everything should work again. It looks to be common problem on 256 with SW above 2.00 and obd2 cs read direct from it.
BigJ (1st July, 2018)
Just wake up car only program original key
If dont no wake up the car check you Zedfull book.
Moes
Verzonden vanaf mijn iPhone met Tapatalk
you have tryed to connect directly by vcds into adress 05 ? But you must make warning turn signal and undipped headlights. so you wake up the can bus without ingnition.
vcds can t touch for this car
Connect 2 fuse too Together wake up the car now you can learn original key too car
Its diferent systemnot a7
Renault ECU tool / IO terminal / A.S.W
niceevil (27th June, 2018)
