Passat b7 Login failed
Results 1 to 11 of 11
    Oct 2010
    Default Passat b7 Login failed
    Hello, I need to read Immo data from cluster but I can’t login.
    I use fvdi and immoplus process without good results.
    The car is ve Passat b7 year 2014
    Cluster 3aa920781a vdo
    Eeprom 24lc64
    Regards, Joze
    Enviado desde mi iPhone utilizando Tapatalk
    Germany
    Immo is not in cluster. Read ecu or comfort module!
    Greets MR...
    Oct 2010
    I forgot to up the file
    24lc64.rar
    Sorry
    Oct 2010
    Hello again, now the Passat’s owner ask me if it’s possible to do an odometer correction too
    Can you help me ? I usually don’t do this but if he want I want to try
    Joze
    Jun 2013
    US model?
    Euro model?
    Oct 2010
    I think it’s Euro model, but how can I know it ?
    Jun 2013
    US model - key with flip metal blade and ignition. Like old Passat B5.5
    Euro model - key with integrated hidden plastic key. Put key in a key slot. And push in to start.
    Oct 2010
    Ok, thanks for answer, this Passat is European version
    Jun 2013
    Then no immo in the cluster.
    CCM.
    Oct 2010
    Ok, thanks.
    So, it,s possible to do an odometer correction y that vehicle?
    Oct 2010
    Hello again, I try to adjust kilometer but fvdi tells “ non standard failed login “ like when I try to read immo data.
    I read 24lc64 and put dump into fvdi prepare login, then fvdi generate new dump to load into eeprom, but again the system tells “ non standard failed login “ and can’t edit odometer
    Thanks in advance
    Joze
