07 sprinter sw1037398897 ori virgin.rar
Here you go
Here you go
Col19 (26th November, 2023), danosull (9th February, 2021), nickolasd (19th June, 2018), Pyromaniak (11th April, 2024), wflseba (25th September, 2018)
this dump still contains old vin number, do i need to fff it or something else or dont touch?
It should allow you to synch and start.
I dont think it is autosynch, so star will be needed.
If you need old ecu to transfer data with star, or can write vin 1 first time only, i dont now.
This is made with the Avdi dump tool.
I never used it myself, so i can only guess.
Most take dumps, from a complete set.
cleevesy (22nd July, 2022), Col19 (26th November, 2023), danosull (5th February, 2021), massiwe (25th March, 2019), Pyromaniak (11th April, 2024)
No, no need change VIN in dump, it will be done while you personalizing ecu, need to enter VIN manualy using MB star.
If previous virgin file doesn't work, do with my solution.
old ecu is dead and not readable even on a bench. otherwise i would just clone it.
keturi please provide pass for archive.
keturi your file didnt work i tested it.
Rob h file worked perfect.
thank you both of you for help.
keturi if I could have pass please i would like to try this my sprinter has the same id number thanks I know its an old post. just hoping you remeber pass
