Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    Jan 2017
    USA ����
    Default OBDSTAR P001 for X300DP EEPROM , RFID, Key Renew adapter + toyota smart key emulators
    OBDSTAR P001 Programmer for X300 DP/Key Master DP
    OBDSTAR P001= EEPROM adapter+ RFID adapter + Key Renew adapter +Free Toyota Smart Key Emulators
    On the basis of original adapter features, P001 programmer, integrated with the EEPROM adapter, RFID adapter and Key Renew adapter, is a multifunctional programmer.
    It brings a brand new experience, which not only allows auto technician to reduce more cumbersome procedures, but also can be compatible with simulated smart keys to realize the Toyota all lost.
    P001 programmer uses dual coils with stronger signal, supporting a wider range of RFID. It is also required in recent model upgrades, as follow:
    • Ferrari 458/F12/F149;
    • Maserati mechanical key;
    • Fiat 500/Viaggio/Palio/Siena/Boyue/Pailang/Ottimo, etc.
    • Iveco;
    • Alfa Romeo;
    • Volkswagen MQB;
    • Toyota simulated cards;
    • BMW;
    • Porsche;
    What device does P001 programmer work with?
    P001 works with OBDSTAR X300 DP/Key Master DP/X300 DP Plus both full and standard version. Cannot used with other OBDSTAR key programmers, X100 Pro/X300 pro3 etc. Please provide your X300 tablet Serial Number when purchase the P001 adapter.
    P001 programmer (full package):
    P001 programmer unit + C001 circuit board + C002 circuit board + W001 data cable + W002 data cable + W003 data cable + Toyota simulated smart keys (free);
    2 circuit boards for eeprom
    3 cables for eeprom and key renew
    4 emulators(5th is in development)
    w001: solder type wire
    w002: 8 leg chip connector clamp
    w003: 2 alligator clips and 2 probes for key renew
    About Toyota simulated smart key
    1.Why use a Toyota simulated smart key?
    For the Toyota/Lexus 2007-2016 models, if all smart keys are lost, the instrument table must be removed and the ECU must be replaced. The cost is very high!
    This Toyota simulated smart key can generate a Toyota key with our devices in the case of all keys lost, so the ignition switch can be turned on, and then a new smart key can be added and programmed with our devices.
    2.What are the advantages of the Toyota simulated smart key?
    • Save costs;
    • Reusable.
    3. How many types of Toyota simulated smart keys in total?
    There are 4 types at present, and the 5th one is in development.
    4. Which type of smart keys can be simulated?
    Simulated key 1 applies to the vehicle with 94/D4 type of smart key;
    Simulated key 2 applies to the vehicle with 98 type of smart key;
    Simulated key 3 applies to the vehicle with 88/A8 type of smart key;
    Simulated key 4 applies to the vehicle with A9 type of smart key;
    5. can i use these emulators with other programmers?
    yes they can be used with the tango key programmer but not with the lonsdor K518ISE
  2. The Following 2 Users Say Thank You to sleepyrz For This Useful Post:
    djollie (20th June, 2018), pitake (4th July, 2018)
  3. #2
    Apr 2018
    nice programmer
    rob h's Avatar
    May 2011
    does it read european toyotas, all keys lost.
    Apr 2018
    also comes the Key Master DP Plus
    knew from their official Facebook
    Apr 2018
    http://en.obdstar.com/product/Key/3361.html
    details of their key master dp plus
    Oct 2017
    again try to steal money.
    i hate obdstar.they want us to buy new dp plus ..why they dont make compatible with older hardware like x300 dp.
    just to make another attempt to empty our pockets.
    not saluted.
  8. The Following 2 Users Say Thank You to Asifmehmmod1 For This Useful Post:
    gokart (4th July, 2018), hcip (23rd June, 2018)
  9. #7
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Joke: the wehicle list isn't available...
  10. #8
    Jan 2017
    USA ����
    so.....yea
    i have no clue i just totally copy pasted that from the website i found it on
    tempted to get one to play with tho
  11. #9
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    How does this work? Works as they promise or trying to scam us another way?
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  12. #10
    hcip's Avatar
    Attached is the Help file from my XDP (Toyota Smartkey AllkeyLost)
    I previously test the menu in toyota 2009 year w/ smartkey:
    Toyota/Scion/Lexus Version32.02
    Read eeprom === successful (note: you need to read repeatedly and backup because sometimes it read all data "0000s" value)
    Reset Smart ECU === it appeared function not suppurted
    add smartkey == ok
    I have not tested yet the simulate smarkey because I have no P001 option yet, need internet connection to do this, I will try it soon, I will gamble for that price, its a little cheap
  13. The Following 2 Users Say Thank You to hcip For This Useful Post:
    HeXeN (27th June, 2018), scotlock (23rd June, 2018)
  14. #11
    Apr 2018
    Heard that X300 DP will keep updating software
  15. #12
    Aug 2010
    why this company produce every one or half year a new device , they take some good update from x100pro and they will stop update for other device .. this not good for us ..
  16. #13
    HeXeN's Avatar
    Mar 2015
    x100pro also keep updating - question is what is quality of that updates?
  17. #14
    Apr 2018
    Every company makes new products
    X100 pro was also new device when it first came out.
  18. #15
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Quote Originally Posted by SMP7 View Post
    And the Renault Type NN was the fastest car when Ferenc Szisz won the first Formula 1 with it...
  19. The Following User Says Thank You to PocketHero For This Useful Post:
    szkeptmen (21st May, 2019)
