Results 1 to 4 of 4
    Dec 2015
    Portugal
    Default Mercedes W210 EZS/EIS problem?
    I have a strange problem with a w210.
    Key works on EIS and ESL works fine also.
    Start the engine, but when taking out the key from EIS, the engine and dashboard still working. I have to disconnect battery to shut it off.
    After remove key, the ESL works, but if i put it back on EIS/EZS the key don't turn anymore, just after disconnecting battery.
    I read DTC's from EIS/EZS and give this code: B1156 control module electrical fault.
    Any idea what could be the problem and how can I fix it?
    https://youtu.be/GV2ctrPJyU8
    Enviado do meu MI 6 através do Tapatalk
    Tools: AVDI, Im608, VVDI 2, VVDI MB, T-Code, SBB
    Eeprom: VVDI Prog, Orange, Tango, TMPro, R270, ABPROG
    Other: VVDI Mini Key Tool, Key Tool, KD-X2
    Electronic key machine: Silca Triax, Idea, Unocode
    workshop
    buy donor and clone eis
  3. The Following User Says Thank You to mercis For This Useful Post:
    lmqcatarino (19th June, 2018)
    Dec 2015
    Portugal
    Quote Originally Posted by mercis View Post
    On bench, EIS works fine together with ESL.
    I make some additional tests on car and notice this:
    If I just insert and remove key from EIS, ESL work fine.
    If turn key to first EIS position and turn back and remove it ESL works fine.
    If turn key to second EIS position (dashboard on) when turn key back and remove it, dashboard stays on and esl don't work.
    workshop
    maybe esl dont close,test with emulator
