If you not open the ECU carefully, may happen like this . I have been faced this issue with hyundai.
HI! I have 2012 fiat 500 North America, customer vs install battery - native ECU -died, no communication. I take another ECU with the same part number and resolder eeprom from original to another donor, but after that another ECU not answer also( but before i install and it good communication), want is problem? I attached all here, please help!
Eeprom checksum error.
What is your ECU?
Make virgin and adapt to car better than clone non working eeprom.
Adamon777 (22nd June, 2018)
If it is diesel marelli you have to make full bdm read(flash micro) and put it to donor ecu..
@Adamon777 did you find a solution?
Txs
Hello, I have same problem, I haven't swapped eeprom yet but I know that needs to be either clone or virginized by being read the whole flash, once I needed to program a ecu for a ram promaster, I tried with a used one but I couldn't make it work, I had to buy a new one, and at the time I load the calibration, serial number and security code was loaded from bcm. I think is the same system because both shows the same error "minikript not match"
Did you find out how to make it work?
Good afternoon; Can someone help me know how to read the 8GMC.C1 module for fiat 500 with ktag clone. I appreciate the support and assistance
hello, can you tell me is it automatic or manual
