Results 1 to 3 of 3
    Default Peugeot 308 2009 IMMO OFF - Bosch MEV17.4 0261201863
    hi friends i need your help to immo off or virgine file for this ecu
    flash and eeprom attached
    regards and thank in advanced
  2. The Following User Says Thank You to naelraddad For This Useful Post:
    baykorg (28th January, 2022)
  3. #2
    Quote Originally Posted by naelraddad View Post
    any idea friends with tested solution
    i tried to immo off the previous file with immotool v1.5 cracked by friend Luise Abdre
    the car started for one our after that it stopped starting ( it crank without starting ) so i hope to get tested solution for this car
    regards
    thanks solved it was galetto check sum error
    regards
