Results 1 to 4 of 4
    bidu20's Avatar
    Jun 2016
    Default VW Sharan 2003 Dump corrupt
    I have a Sharan Dash with problem no communication with other units and VCDS. I read eeprom 93c86 with elenec.
    I found a other Dump with same Dash Number. With this dump communication is OK. But the Speedgauge and counter is not working. Speedsignal comes over CAN BUS.
    Can someone repair my corrupt Dump or modify the new dump?
    Both Dumps in attach..
    Dashnumber: 7M3 920 840 M
    VDO 110.080/032/012
    VIN: WVWZZZ7MZ4V007095
    Thanks!
    rubin_miki's Avatar
    Nov 2008
    MAKEDONIJA PRILEP
    here i orig but v59,we dont know what version is yours but you can try.
  3. The Following User Says Thank You to rubin_miki For This Useful Post:
    bidu20 (20th June, 2018)
    bidu20's Avatar
    Jun 2016
    thanks my original is v59.
    With your dump the speedo works but same problem with diagnostics and communication..
    That's a bit weird :-/
    rubin_miki's Avatar
    Nov 2008
    MAKEDONIJA PRILEP
    did you try with other diag tool?vw sharan that model sometimes have problem with vcds,before one week i have problem with airbag on same model sharan i dont have diag with airbag module but with other diag tool i have comunication
