Hey members l have nissan eligrand with immo reader made mexico but different with other please check on picture . please l need pin code .car lost all key .thanks
hey. sorry members this picture immo nissan elgrand and which transpoder type it use on this immo thanks
"L" type needs bcm conversion, you need to read the bcm code or see bmc module sticker post the code to convert, uses tp12 id46 blank transponder
convet 42 (20th June, 2018)
thanks member l will test and give result .thanks
Hey member l read bcm code is 12FFF.and l Calculate pin it give pin 0283.l try to code on car it pin code error. Or model is 2003. Vin E51-021072. wrong pin code. Please member can help pin code on this car thanks on advance
can you take a pic from bcm and bcm sticker?
