Results 1 to 5 of 5
    Default astra twintop 2007 no communication obd
    hi I have a 2007 twintop astra that come in with a roof stuck, I have no power to the obd socket, fuse 24 revision b fusebox has not blown, It was working, but not now, when I could communicate with the ecu's there was no response from the roof ecu, using op-com, can any one help thanks
    Apr 2012
    Wonderland
    same here, have you solved?
    ProTuner since 1999
    Mar 2020
    in the field
    try feeding 12v from a different obd contact
    Apr 2012
    Wonderland
    Quote Originally Posted by pawl View Post
    hi Pawl, i have solved 12v on obd socket but roof ecu don't reply on diag.
    i know twintop roof ecu are weak, i think mine is faulty
    ProTuner since 1999
    Mar 2020
    in the field
    I have such an astre in the workshop, I can check power and communication points tomorrow
