Infiniti Q50 Crash
Results 1 to 15 of 15
    Pavel-DN's Avatar
    Nov 2010
    Spain
    Default Infiniti Q50 Crash
    Can you help me with crash infiniti Q50 eeprom 95128
    988204AM0A
    0285012482
    badziewo's Avatar
    Feb 2016
    Universe
    Here you go
  3. The Following User Says Thank You to badziewo For This Useful Post:
    Pavel-DN (20th June, 2018)
    Pavel-DN's Avatar
    Nov 2010
    Spain
    Quote Originally Posted by badziewo View Post
    Here you go
    Error B142A
    badziewo's Avatar
    Feb 2016
    Universe
    DTC B142A IGNITION VOLTAGE
    Ignition voltage is supplied to the air bag diagnosis sensor unit when the ignition is in the ON position. The air bag diagnosis sensor unit will monitor for low or high ignition voltage.
    Check fuses
  6. The Following User Says Thank You to badziewo For This Useful Post:
    Pavel-DN (21st June, 2018)
    Pavel-DN's Avatar
    Nov 2010
    Spain
    Check fuses
    After charging the battery i have not dtc B142A, but I have DTC U3FFF. If I fill original dump with '00' in lines 0E80 & 0E90 - I have dtc B0591. If Ifill 918- 95F with FF - I have dtc U3FFF
  8. #6
    badziewo's Avatar
    Feb 2016
    Universe
    Load your original crash bin back to eeprom and scan your car. Report back DTC after scan
  9. #7
    Pavel-DN's Avatar
    Nov 2010
    Spain
    With original bin: DTC B1425 - activ and B2687, B2684, B2681, B142A - stored
  10. #8
    badziewo's Avatar
    Feb 2016
    Universe
    Try to erase codes with scanner and rescan it . Post DTC again
  11. #9
    Pavel-DN's Avatar
    Nov 2010
    Spain
    This is after erase codes with scanner. Active only B1425 - rear crash, but other dtc can't clear
  12. #10
    badziewo's Avatar
    Feb 2016
    Universe
    You can’t clear code b142A either ?
    This is the only code left in my clear file.
    What scanner are you using to clear codes?
  13. The Following User Says Thank You to badziewo For This Useful Post:
    Pavel-DN (26th June, 2018)
  14. #11
    Pavel-DN's Avatar
    Nov 2010
    Spain
    If I have active B1425 - then a could not clear nothing.
    With you clear fille after charging the battery i have not dtc B142A, but I have DTC U3FFF with FVDI and Launch, and no codes with Consult 3. But ligh on dashboard does not go out.
    I think that car has problem not only with airbag.
    Thanks for help, I will go to long weekend. Will see tuesday.
  15. #12
    Pavel-DN's Avatar
    Nov 2010
    Spain
    Here you go
    Your solutions is correct, Thanks. Problem with precrash system. Solved
  16. #13
    Jun 2020
    Default Crash infinity Q70 2015 0285012482
    Помогите очистить место аварии
    98820 4АМОА
    0 285 012 482
    eeprom 95128
    благодарить
  17. #14
    Jun 2020
    Help clean the crash
    98820 4AMOA
    0 285 012 482
    eeprom 95128
    thank
  18. #15
    Sep 2022
    Check fuses
    Hi, I have same issue... My airbags are intact but crash zone sensor was missing. I installed new one but both cables which go into sensor are touching the frame (it seems..). Could you please advise what to do?
