Can you help me with crash infiniti Q50 eeprom 95128
988204AM0A
0285012482
988204AM0A
0285012482
Here you go
Pavel-DN (20th June, 2018)
DTC B142A IGNITION VOLTAGE
Ignition voltage is supplied to the air bag diagnosis sensor unit when the ignition is in the ON position. The air bag diagnosis sensor unit will monitor for low or high ignition voltage.
Check fuses
Pavel-DN (21st June, 2018)
Load your original crash bin back to eeprom and scan your car. Report back DTC after scan
Try to erase codes with scanner and rescan it . Post DTC again
This is after erase codes with scanner. Active only B1425 - rear crash, but other dtc can't clear
You can’t clear code b142A either ?
This is the only code left in my clear file.
What scanner are you using to clear codes?
Pavel-DN (26th June, 2018)
If I have active B1425 - then a could not clear nothing.
With you clear fille after charging the battery i have not dtc B142A, but I have DTC U3FFF with FVDI and Launch, and no codes with Consult 3. But ligh on dashboard does not go out.
I think that car has problem not only with airbag.
Thanks for help, I will go to long weekend. Will see tuesday.
Помогите очистить место аварии
98820 4АМОА
0 285 012 482
eeprom 95128
благодарить
Help clean the crash
98820 4AMOA
0 285 012 482
eeprom 95128
thank
