range rover 4.4 tdv8
Results 1 to 5 of 5
    Default range rover 4.4 tdv8
    hi friends, please need remove dpf and dtc from file, car range rover 4.4 tdv8, ecu edc17cp11. i make dpf already but always have reduce power and obd error p006a.
    thanks friends
    please friends can someone give a help???
    pike's Avatar
    Sep 2013
    Arrow Range Rover 4.4 TD dpf off
    here DPF off file.
  4. The Following 2 Users Say Thank You to pike For This Useful Post:
    chipdanix (21st June, 2018), ngoncalo (24th June, 2018)
    Friend thank a lot for help me but file not ok, i think always have error and reduce power. can you fix it?
    pike's Avatar
    Sep 2013
    You have P0235-94, P00BD-07, P006A-00, P2263-22 also?
    These DTCs indicate a leak from the ductwork.
  7. The Following User Says Thank You to pike For This Useful Post:
    ngoncalo (27th June, 2018)
