jaguar xf 250 2.2 diesel dead
Results 1 to 7 of 7
    Default jaguar xf 250 2.2 diesel dead
    hello
    i have jaguar xf250, 2.2 diesel year 2013 , vin - SAJAC05VXEVT02200
    problem in car central lock not working after some one remove battery wire
    i read on internet this is cjb & kvm & bcm problem
    customer gone at dealer & compnay also told change both bcm
    that type of car dead in daiognostic i heard not sure
    here i attach photo of it
    so for security i decide all 2 bcm 9s12xet256 data
    but after read car no key found
    front bcm 9s12xet256 data may bi problem bcoz eeprom read 4kb & when i try to read with vvdi prog mismatched partition in eeprom
    now in scanner vin error in bcm car not start
    here i attach all picture & data of both bcm
    anyone please hepl me
    Oct 2017
    Australia
    Does the vehicle start up using the backup system. IE: there is panel to the right of under the steering column (right r/h drive left l/h drive) which has the transponder pickup beyond it. Hold the smart key against the panel to see if it will start.
    ok i check but scanner clear say no vin in bcm
    thanks for help
    Oct 2017
    Australia
    Hi, these cars are notorious for having security problems and can be hit or miss whether you get around them. The first reason for asking if it starts up on the backup system is that you can use a scanner like Autologic to run immobilization reset (because you control of the ignition) to recover the situation. The second suggestion is for some reason that the BCM has lost its identity. Therefore you may be able to reprogram it as a new unit i.e. again using Autologic. I do not know whether these will help you but all the best.
  5. The Following User Says Thank You to Paddjohn For This Useful Post:
    maruti (23rd June, 2018)
    hello
    thanks for good help , i change used bcm same parts number & configure with jlr thanks to alek (mhh) & car start & central lock aslo working
    Oct 2017
    Australia
    B102B-67 Passive Key - Signal incorrect after event
    Possible Causes
    CJB fault
    Low speed CAN fault
    Remote Keyless Entry (RKE)
    module fault
    Write target SID
    synchronisation error
    following re-programming
    Possible Causes
    Check power and ground supplies to CJB and RKE
    module. Check CAN communications between CJB
    and RKE module. Re-synchronise ID by
    re-configuring the RKE module as a new module
    Fault code coped from work shop Manual
    Oct 2017
    Australia
    Possible Causes
    CJB fault
    Low speed CAN fault
    module fault
    Write target SID
    Possible Causes
