Results 1 to 15 of 27
    Jan 2018
    Default 2012 Toyota Yaris no keys
    This vehicle has been bought from an auction with no working smart key available, another locksmith upon removing the the smart box noticed that every 8 legged eeprom had been off the board!
    Upon reading the correct chip ST95160 the data on the chip is wrong, so my question is, has anyone got a virgin file I can try please?
    I have attached an image of the box
    Andy.
    Oct 2017
    try with tango smart toyota+..
  3. The Following User Says Thank You to Asifmehmmod1 For This Useful Post:
    GeminiAutoLock (22nd June, 2018)
    klaudio's Avatar
    Jul 2016
    Quote Originally Posted by GeminiAutoLock View Post
    Andy.
    Found this from another member is a virgin file, not sure if it will work, you're missing all 8 legs eeprom, you should get used smart box and write virgin, if doesn't work you will need to sync with ecu and steering lock, should be a set somewhere in the forum.
    ​Some people just want glory instead of acknowledgment.
    Thanks and reputation is earned, not ask for.
    Have a nice day.
  5. The Following User Says Thank You to klaudio For This Useful Post:
  6. #4
    Jan 2018
    Thanks klaudio but this file didnt work. When using AVDI to create a file using the new key we have bought from the dealer AVDI is asking to use a 98 Tiris DST+ key, the correct key for this vehicle is a Valeo 899040D100, this smart key has a ID46 PCF7945 chip.
    The model number for the car is NSP130R-CHXGKW. Thee eeprom is a ST95160.
    Has anyone got the correct filr?
    Andy
    klaudio's Avatar
    Jul 2016
    Andy
    found this file that could be what you need, i think is a virgin file and don't know if it will work, is a start, 899040D100 should be the correct key and is not id46.
    Have a nice day.
  8. The Following User Says Thank You to klaudio For This Useful Post:
    GeminiAutoLock (23rd June, 2018)
  9. #6
    Jan 2018
    Here is the Vin number
  10. #7
    Oct 2017
    Toyota never use chip 46..
    smart key start with tirish 4d ...
  11. #8
    Jan 2018
    This is the key.
  12. The Following User Says Thank You to GeminiAutoLock For This Useful Post:
    hcip (23rd June, 2018)
  13. #9
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Must be error
  14. #10
    klaudio's Avatar
    Jul 2016
    Quote Originally Posted by drugowaz View Post
    Must be error
    I looked it up, there are id46 for toyotas, didn't find any solutions only people looking for answers. I think there were only suggestion to replace with new.
    Have a nice day.
  15. The Following User Says Thank You to klaudio For This Useful Post:
    GeminiAutoLock (25th June, 2018)
  16. #11
    autochei's Avatar
    Mar 2013
    romania
  17. The Following 2 Users Say Thank You to autochei For This Useful Post:
    doctore (25th June, 2018), GeminiAutoLock (26th June, 2018)
  18. #12
    Jan 2018
    Thanks for the file you sent klaudio but again it failed to solve the problem, its not a virgin file and AVDI recognises the file as an unknown file. If you try and reset the ecu it starts the procedure and says its going to take 15 mins please leave the drivers door open, it says complete after 30 secs and hasnt reset the ecu.
    Rang Toyota yesterday to see if we could get a new Smart Box part no. 89990-0D030 was told this is now a discontinued part!
    Has anyone else got a virgin file we can try?
    Andy.
  19. The Following User Says Thank You to GeminiAutoLock For This Useful Post:
    fred77 (8th April, 2023)
  20. #13
    Jan 2018
    This is not the key for this vehicle.
    Andy.
  21. #14
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    I search the information about this car according to your sticker
    Sticker = NSP130R-CHXGKW
    Smart ECU = 89990-0D080
    SmartKey = 89904-0D100
    http://www.car-keys-online.com/produ...904-0d100.html
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  22. #15
    klaudio's Avatar
    Jul 2016
    Genuine Toyota Yaris Smart Remote Key.
    Toyota Part numbers 89904-0D100
    2 Buttons: Lock & Unlock
    Transponder: ID46 - PCF7945
    Frequency: 433 Mhz
    Key Blade: Not Included
    id46 hope not to run across this one. I see a few smart key ecu used ones online, didn't see one with a key as a set, not sure about programming.
    https://www.partsplanet.eu/en/catalo...90-0d030_2017/
    Have a nice day.
  23. The Following User Says Thank You to klaudio For This Useful Post:
    GeminiAutoLock (28th June, 2018)
