Your problem in not a coding, the vin in the dash and cas is not same.
Dash is red dot?
Hi friends
I need some help yours with BMW E92, 335d coding VO and to write VIN
History is , on car was losted ECU CAS and keys,
i bought a ECU SET ECU+CAS+KEY from donor E91,
i put ECU SET on car and it worked without any probs
I bought BN012 from abrites to code VO-write VIN, coding VO i followed all the steps correctly and VO coded with success said by AVDI SW but in real it doesnt work correctly,
because i cant reset any service type on car, i tried using AVDI service reset directly but doesnt work
Alek from AVDI team tried by teamviewer but without success some friends tried to help but nothing
Here is flash eeprom from CAS and ECU i can gratify to solve it
Thanks for your time and attenction
Cheers
Press "THANKS" button. just one click, CHEERS
Dash is red dot?
electrones (25th June, 2018)
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
doctore (25th June, 2018), electrones (23rd June, 2018)
i´ll report tomorrow friend
CKS is ok or need made it with FGtech!?
thanks in advance
cheers
................................ mistake.............................
Try to use ncsexpert. Read ori vo from frm and write it to cas. You won’t have problem because power class is same to both cas files.
Professional BMW immo solutions
Macedonia is one and GREEK!!!
doctore (23rd June, 2018), electrones (25th June, 2018)
Thanks m8, u were right after write dumps with vin everything is solved with service reset
Thanks m8, for your time, collaboration probs is solved
Cheers
Thanks bearheroes, after write dumps sent by kiska it´s solved
THanks
Cheers
kiszka (25th June, 2018)
