Results 1 to 9 of 9
    Feb 2017
    Default mercedes A140 help please
    Hi mates,
    I have a problem with 2001 mercedes A140 W168.The car was locked with remote control and the remote got broken and it can not open the car anymore but the transponder is still okay.I opened the car with the mechanical key but when i try to start the car i get"start error" on dash.
    please i need to know if it is possible to program a "second hand" key to this car? if not, then how to solve this issue?
    Thanks in advance,regards.
    Jul 2010
    EU
    transponder is not ok , if transponder is ok car will start , if not will got START ERROR . check transponder whit reader , no way second hand key for this car only by immo dump ,
  3. The Following User Says Thank You to iozo For This Useful Post:
    ecu repair (22nd June, 2018)
    Feb 2017
    Thank you mate for your reply.I have read the transponder and it is okay(not defective) but maybe somebody have tried to program it before and the programming was not good.Any way i will read the immo box data and check.
    Thanks again for your support.
    Feb 2017
    Here is the immo file and the key info.I have tried to reprogram the transponder but it did not work(must be new)and i am not sure if this key belongs to this car or not...anyway i am wondering if anybody can write this key info into the immo file.
    Thanks in advance.
  6. #5
    ThiagoArgentino's Avatar
    May 2016
    Brazil
    Quote Originally Posted by ecu repair View Post
    Thanks in advance.
    Test and report
    Solutions in the area of automotive coded keys, all automakers.
  7. The Following User Says Thank You to ThiagoArgentino For This Useful Post:
  8. #6
    Feb 2017
    Thank you mate i will try it and report it back.
  9. #7
    Feb 2017
    Hi mate,I am sorry but it did not work and still have "start error" on dash...please check the picture for the drive authorization status.Any further help is much appreciated,thanks.
  10. #8
    szengen's Avatar
    Jan 2017
    Poland
    the transponder programs well the old "gambit" and carprog, you have to deal with the synchronization
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
  11. #9
    Feb 2018
    Hi, what are your mistakes in ecu? You have to do ecu virgins and add a star diagnosis, as you will want to insert a correct virgin file here.
