Page 1 of 2 12 LastLast
Results 1 to 15 of 27
Hybrid View
    Dec 2011
    Nottingham
    Default BMW 1 Series F20 2011 FEM Dealer Key Programming
    Hi all,
    Hoping someone can help.
    I have a BMW F20 2011 FEM Keyless lost keys. Unfortunately VVDI2 cannot read isn from this particular ECU so I ordered key from the dealer. Connected VVDI2 and can read FEM (all keys are enabled). But the problem is that because the alarm is going off (had to manually unlock the vehicle) it won't allow me to synchronize the new remote.
    Anyone know how to disable this to allow new key to match (dealer key). I have VVDI2 (all auth), BMW ICOM and Launch.
    Usually when I buy FEM dealer key, I would just unlock using working remote, leave working remote away from vehicle. Put new remote near steering column and hold start/stop button.
    I also experiment with another F20. If you lock the vehicle with remote. Then open with key (so alarm goes off) and you press start/stop button it does not give you message on dash "key not found"
    Surely something simple
    Fallen's Avatar
    Dec 2009
    It works the same way, just leave it there longer.
    Dec 2011
    Nottingham
    Ttried that buddy, but only for a minute or so. How much longer are we talking?
    drugowaz's Avatar
    Mar 2015
    Lithuania
    F20 2011 year is FEM its ????
    Key from dealer no need add nothing just put near coil and go.
    This year it shoud be cas system
    Renault ECU tool / IO terminal / A.S.W
    Dec 2011
    Nottingham
    Quote Originally Posted by drugowaz View Post
    This year is FEM. F20 (name gives it away) read the original post please...
    rola1971's Avatar
    Jun 2014
    Dublin
    yes if it is F20 it is FEM
    Gavra's Avatar
    Jul 2010
    Belgrade/Melbourne
    Dealer key for FEM is already coded...... just use it , or someone has played with car in the past
    Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
    Dec 2011
    Nottingham
    Quote Originally Posted by Gavra View Post
    Nobody played with car. Just keys lost. If you read the original post, because alarm is going off won't allow you to use a new remote. I'm looking for a solution for this problem!
    Gavra's Avatar
    Jul 2010
    Belgrade/Melbourne
    Prepare ISTA and send TV if you can wait Monday, I will help you.
  10. The Following User Says Thank You to Gavra For This Useful Post:
    Autowave (23rd June, 2018)
  11. #10
    Dec 2011
    Nottingham
    That's great, going to try as fallen suggested but if not I'll take you up on the offer. What time would suit you? What would you actually do (maybe I can try myself)
    Appreciate everyone's input
  12. #11
    Dec 2009
    Any news on this? I have the same situation, key ordered from dealer, but car doesn't accept it.
  13. #12
    Dec 2011
    Nottingham
    Quote Originally Posted by EMCE159 View Post
    Hi, I have not sorted this yet. Tried Fallen's method but not succesful. I will connect ISTA later today and report. I have 2 of these sitting in my garage both with exactly the same situation so we can clearly rule out any previous tampering. If you figure it out please post and I will do the same.
  14. #13
    Apr 2010
    Quote Originally Posted by Autowave View Post
    Idea that may or may not work.
    What about making a second key on the bench using the dealer key to get the isn?
    With vvdi2 it activated the keys I had made once the fem was reinstalled. Not sure if it would matter the car was locked with the fob as it would be the same as akl with the ability to read the ecu isn.
    Have not tried this, just a brainstorm for the given situation.
    Sent from my SM-G930W8 using Tapatalk
  15. The Following User Says Thank You to dmp For This Useful Post:
    Autowave (2nd July, 2018)
  16. #14
    Fallen's Avatar
    Dec 2009
    I had exactly the same car a few weeks back.
    Cluster did not produce the hold key near column message when I pressed the start button.
    The car was stolen and recovered and I had to unlock it by picking it, there was no alarm but it had been locked by the remote.
    If you check, there should be a signal coming from the emergency coil when you press the start stop button.
    I had to hold it there, with the key continually pressed for about 3 minutes before it would accept the key.
  17. The Following User Says Thank You to Fallen For This Useful Post:
  18. #15
    Dec 2011
    Nottingham
    Quote Originally Posted by Fallen View Post
    Thank you, I'll give it another go tomorrow!
