Results 1 to 9 of 9
    Feb 2018
    Default A3 8P 2010 dashborad dead
    my colleagues, I wanted to change the course in the audi a3 8p 2010 fvdi and killed the counter.
    Help me fix some flash?
    8P0920932G
    Dec 2010
    for the flash to be repaired it needs to be read by a programmer and after that the file will be repaired and if you have done.
    Feb 2012
    autobo's Avatar
    May 2014
    Bulgaria
    If you have DP3 try to change mileage again,and dash will alive.
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by autobo View Post
    dp3 is best known as diagprog3..
    you mean, digiprog. correct if you try again dash come back alive.
    autobo's Avatar
    May 2014
    Bulgaria
    Yes,I mean Digiprog III.
    Feb 2018
    digiprog 3 has no connection with the meter
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by Michal200848 View Post
    most likely problem digiprog.
    Brolk's Avatar
    May 2016
    ARGENTINA Bs.As
    hi
    photo dash
    Brolk..
    Press "THANKS" button.
