Results 1 to 9 of 9
    alexandrosts's Avatar
    Feb 2017
    there where civilization started
    Default How to read mcu with adapter 10 carprog help
    Hi I apologise for opening a new topic with separate questions I just need help with reading immo box mcu from a mb sprinter so I can disable immo I have carprog but I don't know how to connect wires from adapter a10 please help
    Στάλθηκε από το SM-J320F μου χρησιμοποιώντας Tapatalk
    TO TUNE OR NOT TO TUNE
    Feb 2017
    This is the mcu
    Feb 2017
    And I found this pinout online but it doesn't work
    rafal's Avatar
    UK - PL
    you can use xprog but the best upa for this mcu
    need help
    now my goal is to buy xp-005
    who will help?
    Feb 2017
    i only have carprog is any way i can do it with this?
    Feb 2017
    finaly found it thanks for help
    I traied also to read with carprog but no chance ...can u post here what u did ?
    Feb 2017
    sprinter_solder.JPGthis is the proper way of reading it, at least worked for me if you need more info let me know
  9. The Following User Says Thank You to alexandrosts For This Useful Post:
    datapage (10th June, 2020)
  10. #9
    Feb 2017
    use the adapter a10 and go on the points like the pic shows and then go under mcu's chose your's and it will work
