what tool did you use to read?
mdp xep100 prog
check again soldering component and try for test if not ok you lost mcu
i think your p-flash is ok
did you use new wiring without remove component or old wiring with two component remove?
HI your P flash is corupt 0X00080000 to 0X0009FFF0 i have now check more Plash readed with XEP100 Pro and same bug on dump. Not read or not complet offset 0X0008000 to 0X0009FFF0. Try my backup but is litle diferent or repair data from my dump
brend (23rd June, 2018), doctore (23rd June, 2018), Ocin (4th February, 2019), pisicik (15th October, 2018), torvellino (23rd June, 2018), Willisodhiambo (15th August, 2019), zlukic (9th July, 2018)
ok thank you I try and inform
old wiring an extracted co-component
Hi, I already had several problems with my (mdp xep100 prog) or read Pflash several times I corrupted the data, I never needed to replace the CAS but have to take the car to BMW to repair the problem (MDP XEP100) not reliable.
The best, and find a PFlash with the same software number
Can someone share connections for old xep100 I have problems with 5m48
I advise you to remove components such as the vvdi prog version
