I take it everyone has the cheap version of carprog? Anyone got the full version to share some thoughts?
Cheers
Cheers
not yet .we wait
anyone new infos?
is this carprog can re-write mileage of bmw750i?
for programmer is good the carprog?if they have not so expensive the programes it will be better
find anyone something for unlock carprog?
I had worked on this in the past with previous versions but could not continue without having the interface.For some people some extra functions worked, for a majority of the others the following error message was displayed
LIB File problem. Delete LIB file and make UPDATE -> INTERNET
I have implemented those changes on the newer version, so if you want to try it you can.If you run without the interface you can see the sub menus for the menus you click on.I will not be held responsible if it renders the interface useless, so i recommend you back up any eeproms internally that you need too.
file lib probleme
file lib probleme
this probleeeem
you didnt expect all the info 2 be in the exe
when u hav full soft, you also are given proper files for them 2 downlaod, in the LIBrary
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
At this stage there is no evidence to suggest otherwiseyou didnt expect all the info 2 be in the exe
The lib error occurs because the features that are now enabled in this version don't match the features that are enabled in the lib file depending on what extras you have paid for, thats why the error occurs.Because i do not have the interface i will never reach that part of the program that needs to be altered.When you pay for extra's the lib file downloaded in the update has had the extra's upgraded for the serial number you have given to them.I've heard that some people have tried to to experiment by altering the lib file to try & unlock it, but with this i exercise caution.There are routines within carprog that can lock the interface from ever working again.
The best way to tackle this & any other interface is to use a program like the one in the link below.If you can first test that carprog can be run on one machine and the device seen over the network then there is no limit as to what can be done.Teamviewer has been suggested but i would only use it as the last resort, cause it means that the machine that has the interface connected to it must have all the tools required to reverse it, that is difficult because of the variables that are involved
USB over Network Solutions - FabulaTech
Thanks !
