Page 1 of 6 123456 LastLast
Results 1 to 15 of 88
    May 2009
    Default Carprog Remove protection
    Hi everyone
    I have this tool(hardware) CARPROG,can anyone good at this remove the protection to open all modules???
    Is this possible?
    Lets try and see if anyone can do it with the help of all...
    Must be a way of open all of this modules......
    I have all details if anyone needs it....
    Cheers
    Eastern Europe
    hi,
    As far as I know each device has a unique serial nr. It can mean that the pc software checks it and enables or disables the future according to the nr. It would mean pc software is the place we have to start looking for the solution. Am I right ?
    regards
    jogi
    May 2009
    Quote Originally Posted by jogi View Post
    hi,
    regards
    jogi
    YOU ARE CORRECT....they have a serial number....
    Cheers
    busaman's Avatar
    suffolk uk
    now that would be something if it is possible.
    Norway
    Do this interface read and wirte flash of psg16 opel/saab ecu?
    BR
    KP
    Eastern Europe
    Quote Originally Posted by kptuning View Post
    NO Idea man. Check their web.
    ht*p://w*w.codecard.lt/carprog/software/opel-psg16-diesel-pump-by-obdii-read/change-mileage-read-pin-reset-ecu-/prod_375.html
    As for the main thread. My pc programming skills are advanced enough to write a reasonable pc software. I'm also able to program some microcontrollers, projects I did are quite complicated. As for r.e. in particular software unpacking, can't help .
    regards
    hi if you have carprog can you help me please !
    http://www.digital-kaos.co.uk/forums...hlight=carprog
    to:MAXIMUS1000
    help me scan protokol write dump
    to Merc Vito via K-line(OBDII).
    istanbul/turkiye
    this program cracked where??
    Member Persia's Avatar
    Persia
    you can edit dumped file with car prog
    DK Veteran glk96000's Avatar
    Free
    Yes
    93Cxx series : 93C06, 93C06 8bit, 93C46, 93C46 8bit, 93S46, 93CS46, 93C56, 93C56 8bit, 93S56, 93CS56, 93C66, 93C66 8bit, 93S66, 93CS66, 93C86, 93C86 8bit, 93S86, 93CS86;
    24Cxx series: 24C00, 24C01, 24C02, 24C04, 24C08, 24C16, 24C32, 24C128
    95xxx series: 95010, 95020, 95040, 95080, 95P08, 95160, 95320
    i had a look at it,what does it do differently when its enabled ? I saw it lists n/a next to most of the devices, but turning that off was straightforward enough.
    Not so easy without hardware to verify.
  13. #13
    busaman's Avatar
    suffolk uk
    i have the hardware i willl test for you.
  14. #14
    May 2009
    Hey, why You dont respect codecard guys products ? I know them verry well. Little bit shame on You, prices in codecard company are not so high
  15. #15
    Asking 350 euro for an emulator for yamaha is VERY HIGH!!!!
    ofcourse we respect them ,but see this as a sport or hobby.
