I have Peugeot 407 1.6 HDi. Propably ECU is broken. I can buy ECU from Citroen C4 with the same engine. My question is: How to identificate, is it 90 or 110hp ECU.
Chris
P.S.
sorry for my english
Chris
P.S.
Don't bother. Because of the way the anti-theft system is designed you CANNOT use 2nd hand ecu's.
Try if somebody can repair it or buy new.
What are the complaints? Do you have diagnostic trouble codes (complete with numbers)?
Identifying the engine is easy: the engine code is in the Vin-number. It is the 6th thru 8th character.
the bsi and engine ecu are a matching pair.
I know that there is a pin code. I have Planet2000 so I can do some things. I'm still learning. On ECU there is no vin code written, so I cannot identify it. New ECU (if I'm not mistaken) costs almost 1000euros..
thx for helping, I'm waiting for more ideas
Chris
Vin is on your vehicle papers or readable through the front window.
if it's the same ecu, you can virginize it and replace the good cartographie of your engine
when you connect it, the ecu take the pin code from bsi and then let's go
How can I virginize it? I heard about BDM100, but I don't have it. Is there any other possibility?
looks like tesco has discountiuned it anyway
http://direct.tesco.com/q/R.100-6962.aspx
i have managed to use secondhand edc15c2 ecu on a 307 you first need to identify ecu what are the numbers on it.
I was thinking about BDM like this
BDM100 module
I heard that it is possible to clean EDC throug Lexia. Does anybody know how to do that?
With lexia you can put new firmware but ilf the ecu was programmed with a vin you cannot do nothing before virginize it
ecu number ?????????????????????????????????????????????????? ??????????????????????????????
u must set immo code for bsi and ecu
Ok, I have now ECU + BSI from Citroen C5. But I need OPM code. I have no idea what it can be. Does somebody know?
