Results 1 to 9 of 9
Thread: KTAG 7.020 help
    Dec 2017
    Deutschland
    Default KTAG 7.020 help
    my Ktag 7020 does not work anymore, all logs are gray can one help me?
    or did you have for me SD card file for 7020?
    Jun 2013
    EU
    Ensure your sd card fits well and no dust on sd contacts
    Dec 2017
    Deutschland
    device is detected
    list are all gray
    Jun 2013
    EU
    Once more, will not repeat again.
    wich operanting system use you
    i have this problem with win7, with xp is all ok
    Dec 2017
    Deutschland
    I use win 7 have tried again sd card out clean, imer still the same device is recognized but lists are gray
    Dec 2017
    Deutschland
    have it now with win xp still trying the same! does anyone have file for ktag, so I rewrite it on sd card ??
    Jun 2013
    EU
    If you already altered sd content in any way or sd is defective will not be that easy to make it work again. Just “Format and write files to sd” will not solve your problem.
    Backup of SD for firmware KTAG 7.020
    https://mega.nz/#!7FVwVbjK!HPNbm12Bb...DRixGT_0ytmpSw
  10. The Following User Says Thank You to pumukyrr For This Useful Post:
    blackcorri (24th June, 2018)
