disconnect tempersture sensor and differenstial pressure sensor and your problem is gone. Remember !! 3.0 tdi have 3 temp sensor from dpf and all must disconnect !!!!
Hi.I try to disable dpf for audi a6 3.0dti 16cp34 1037380431 0281012915 but when write soft with disabled dpf I have dtc (wrong software) I writye back org flash and all is ok.I do same audi one year ago and compare flash with last car and two flash no have difrence.I do not have idea where is the problem I thinks that eeprom is locked.Can anyone help me.
Thanks.
FILE SERVICE
DSG TUNING
File Service
Hi.Thanks for answer but I try all.with disconected 3-sensors, have this dtc with conected sensors too.The problems is that I change only one bit from flash and have dtc-(wrong software).I cange ecu with another one but new ecu wuth difrence software number and write in new ecu org flash,mpc and eeprom the car start good next I change only one bit for example bit for dpf-swich and again have dtc-(wrong software).If anyone have full bdm file flash,mpc and eeprom to write to my ecu to reslove this problem.
Thanks.
read again what I write.... he see temp sensor and show you " wrong software " Check again all sensor, when you have disconnect all sensor this dtc gone.
FILE SERVICE
Hi.Ok can U made file with disabled dpf I will disconect sensors again.And will write your fail.
Thanks.
You Off by switch
nikka (24th June, 2018)
Thanks mate.Thomorow will try.But U disable only swich without disconected temperature sensors.I try this solutions anymore without succes
Bodzio make you file with switch same as yours.....
you need disconnect all 3!! Dpf sensors, not from exhaust but from plugs!!
After disconnect DTC about wrong software disappear...
DSG TUNING
File Service
Yes two disabled dpf swich without disabled dtc for temperature sensors but when I write bodzio012 file and disconect 3-temperature sensors will have dtc for temperature sensors or not?
All will be ok, just write
this is the same file, because you search problem in software??? use your file no need better solution. Disconnect all and works, simply
FILE SERVICE
Thanks forr all help thomorow will write file and will send result thanks again.
