Results 1 to 10 of 10
    Apr 2018
    Default Edc17c46 problem seat leon 2.0 tdi 143hp
    Hello guys.
    I am Khalid from holland. First off all thanks everybody for supporting problems!
    today i remapped a edc17c46 stage 1 with ktag clone. The problem is that when i give gas it stop at 1200 rpm and there is a lot of ehite smoke, so i wrote the oroginal file again and same problem. Can somebody help me!
    May 2017
    Turkey
    Quote Originally Posted by khalidhari View Post
    Hello guys.
    Did you remove and open ecu for remapping?
    Or Did you remap via obd?
    LaraVAG's Avatar
    Jun 2011
    Ktag = boot mode!! Write ORI file, and check DTC by diagnostic
    CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
    EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
    DTC OFF, LIMP HOME MODE OFF!!!
    ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
    HOT/COLD START
    CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
    TRANSLATE DAMOS ENG
    COUNTER FIX - VAG EDC16, EDC17
    ORYGINAL FILES DATA BASE
    START/STOP ON/OFF
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    my customer have same situation last week, wrong connection of one bootpin on ECU later 12+ make all job..
    Need to fit new ecu, same situation like yours.
    DSG TUNING
    File Service
    credoline's Avatar
    Србија
    You want to tell that KTAG manual how to connect (picture) it have wrong connection?
    Do you have right picture showing how to connect BOOT pins?
    BR
    Quote Originally Posted by maajkii View Post
    maajkii's Avatar
    Mar 2017
    Quote Originally Posted by credoline View Post
    BR
    connection of ktag is ok, just need to look closly. he connect wrong pin,he do it bad, no ktag instructions.
    DSG TUNING
    File Service
  7. The Following User Says Thank You to maajkii For This Useful Post:
    credoline (8th August, 2018)
    credoline's Avatar
    Србија
    Thank you. I have one more question related to clone KESS 7.020 KTAG 5.017. With this new KESS i am work 2 times and both of ecu i get problem. First ecu was Ford EDC16C34, read ok, start to erase and stop it. After that i must pull out ecu from car and work via BDM points. Second time was Touareg 2.5 tdi EDC16U1. KESS read, erase, start to write 40 or 60% and error. For the same ecu Galletto read ID but not want to read. MPPS read and write without problems. After this 2 unsuccessfully operation with KESS i am afraid to use him again. Do you have some similar experience or not ? Any advice.
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Kess clone brick edc16, fgtech recover it.
    Best use geniune tools, never brick ecu.
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
  10. #9
    Member rh03's Avatar
    Jul 2017
    France
    [QUOTE = credoline; 3343548] Merci. J'ai une autre question liée au clone KESS 7.020 KTAG 5.017. Avec ce nouveau KESS, je travaille 2 fois et les deux en écus me posent problème. Le premier ecu était Ford EDC16C34, lisez ok, commencez à effacer et à l'arrêter. Après cela, je dois sortir ecu de la voiture et travailler via des points BDM. La deuxième fois était Touareg 2.5 tdi EDC16U1. KESS lit, efface, commence à écrire 40 ou 60% et erreur. Pour le même écu, Galletto a lu l'identifiant mais ne veut pas lire. MPPS lit et écrit sans problèmes. Après cette opération infructueuse avec KESS, j'ai peur de le réutiliser. Avez-vous une expérience similaire ou non? Tout conseil. [/ QUOTE]
    I did ford focus edc16c34 with kess 5.017 sw2.23 rework and no problem, but I had 13.8v during flash.
  11. #10
    Mar 2013
    Europe
    Rework your Kess V2
    I have never problem with my Kess v2
    All VAG EDC16 work Great!
    Never Brick ECU by OBD
