Results 1 to 11 of 11
    HeXeN's Avatar
    Mar 2015
    Default Opel/GM Pin Code Read Obdstar/Lonsdor success rate?
    Up to what year it can read pincode?
    What cars tested?
    rob h's Avatar
    May 2011
    Until end 2017, depending on bcm.
    Failed on a 02-2018 zafira with bosch bsi.
  3. The Following User Says Thank You to rob h For This Useful Post:
    HeXeN (24th June, 2018)
    HeXeN's Avatar
    Mar 2015
    What tool used?
    p1et's Avatar
    Oct 2013
    Lonsdor on Opel pin reading is useless. But maybe under Chevrolet menu it will read some, need to try. On Chevy, Buick it work good.
  6. The Following User Says Thank You to p1et For This Useful Post:
    Feb 2013
    Astra H 2005 read pin fail
  8. #6
    HeXeN's Avatar
    Mar 2015
    Insignia 2010
    pin read ok
    via Chevrolet, type6 (bcm)
  9. The Following User Says Thank You to HeXeN For This Useful Post:
    TERMINATOR1000 (26th June, 2018)
  10. #7
    Apr 2017
    OPEL COMBO C 2009 FAIL
  11. #8
    rob h's Avatar
    May 2011
    Opel combo C, 2009, what bcm type? 24467903
    Pin is easier to get from ecu, so that might be why the pin is not found.
  12. #9
    Apr 2017
    I get pin from instrument panel with zedfull- obdi
  13. #10
    HeXeN's Avatar
    Mar 2015
    from instrument panel or ECU diesel/petrol I get with FVDI 2014
  14. #11
    grzyb26's Avatar
    Jan 2012
    astra j 2011 k518 pin ok
