Results 1 to 11 of 11
Thread: Opel pin code
    Feb 2018
    Default Opel pin code
    Which tool should I buy so that I can read Opel cars security code?
    Oct 2015
    AVDI, Zedfull, SMOK and many others - depends from your budget
  3. The Following User Says Thank You to klesk1986 For This Useful Post:
    BeatsByMe (24th June, 2018)
    Feb 2018
    Espaņa
    Always is better when cheaper is
    Oct 2015
    Quote Originally Posted by TukoSalamanca2 View Post
    So in most cases cheap eeprom programer and brain.exe
    Feb 2018
    Espaņa
    Quote Originally Posted by klesk1986 View Post
    Cheap, fast and easy. hehehe
    rob h's Avatar
    May 2011
    obdstar does many, under gm menu,
  8. The Following User Says Thank You to rob h For This Useful Post:
  9. #7
    Feb 2018
    For 100 euro?
  10. #8
    rob h's Avatar
    May 2011
    obdstar x300dp, a bit over 100 euros i would say!
    i mostly use ioterminal on opel, even that one failed on the 2018.
    Quote Originally Posted by BeatsByMe View Post
    For 100 euro?
  11. The Following User Says Thank You to rob h For This Useful Post:
  12. #9
    Sep 2016
    Did you write to developer from ioterminal?
  13. #10
    Dec 2016
    Quote Originally Posted by rob h View Post
    you use GM "Auto read pin (BCM)" ? With OPEL menu don't work "read security code" ?
    B R
  14. #11
    rob h's Avatar
    May 2011
    I will send the log soon.
    Quote Originally Posted by qeso705 View Post
