Results 1 to 8 of 8
    DK Veteran KWP2000's Avatar
    Default pinout immo box mb vito HC0
    HELLO
    pls hellpmo for pinout mb vito hc0 upausb xprog m
    rob h's Avatar
    May 2011
    Does it look like this?
    MC68HC05X16 (0D62J)
    Default pls hellp mo pinout
    May 2018
    hi if that 0d62j you have solder to hc05bx adapter of xprog
    rob h's Avatar
    May 2011
    4.5 CarProg Mercedes Benz key programmer manual
    This box is similar to w168.
    Google this; 4.5 CarProg Mercedes Benz key programmer manual
    If possible in circuit, then you need to lift some PINS Just like W168.
    Hello Mate,
    Have a look at these connections dedicated for ORANGE FIVE Programmer that may help you.I think these connections are compatible with UPA Programmer and difference should be only the Security Bytes necessary to bypass the MCU security.
    Good Luck, Serge
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by KWP2000 View Post
    HELLO
    best opcion its to remove that mcu and read with xprog like sharm
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
    rob h's Avatar
    May 2011
    vito.jpgHave a look a the posted pictures first, you are way off.
    The pcb layout does not come close to these.
    As i posted, w168 is nearest solution.
    The idea is to read in circuit, carprog gives us a solution.
    Quote Originally Posted by ngakson2002 View Post
    Hello Mate,
    Good Luck, Serge
