Put MBC and you can make with boost what ever you want. Stock turbo was without N75?
Hello I have a friend with TD5 Defender 90 he has very large intercooler and larger vaned turbo. He had a remap previously where he sent ecu off and had it returned tuned. Apparently the guy who did the tune soldered in a boost chip to allow you to boost what you want without it cutting out?? as we have to control the boost using the boost controller as far as I am aware it cant be changed in the map? could someone do a tune for possible 30psi boost?, or give me a little more details on this so called "boost chip" he talks about
thanks all!
HW: 4143
SW: NNW501340
VIN nr.: SALLDVA87YA179801
SW ver.:
Spare:
Engine:
HW Ver.:
SW upg.:
Installation:
Chiptuning - Diesel / Petrol / Stage1,2,3 / HIGH Petrol Tuning
DSG TUNING
DPF / EGR / TVA / SAI / Lambda
Crackle map ( Launch Control + No lift Shift + Antilag )
File Service
PCMFLASH / BFLASH / AMT BST / AMT MPPS / TGFLASH / BITBOX / EDCSUITEPRO - Genuine USER
ah good so just set boost to what you want and increase fuel in the map? thanks! and yes original turbo was just a line coming from boost pipe to actuator an same with new turbo
