Results 1 to 5 of 5
    Nov 2015
    Default BMW X3 airbag MRS5RD
    Pleas help my clear crash from MRS5RD Bosch 0 285 001 870, 65.77-3424581-01, eeprom 95640.
    Thank You.
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Your cleared file, report back.
    Best regards.
    Dragon
  3. The Following User Says Thank You to dragon100 For This Useful Post:
    darka7 (25th June, 2018)
    Nov 2015
    Thank You dragon100 ! I clear it identical, but it dont help my. Airbag dtc is "000055 MRS:Emergency call function". I don't undarstand what's the problem. Maybe You had to encounter an earlier problem with that.
    Sorry my bad english. Thank You.
    dragon100's Avatar
    Jan 2012
    This is tested solution, check all in the car ...
    Best regards.
    Dragon
  6. The Following User Says Thank You to dragon100 For This Useful Post:
    Nov 2015
    I always check all airbag modules in the car , but this module don't work and shows this dtc. I insert another used module and it works well. Thank You very much for Your help.
