Results 1 to 10 of 10
    Mar 2013
    south africa
    Default vito w638 petrol ecu renew
    please help virgin eeprom 24c04 w638 v6 petrol vito
    gtcricardo's Avatar
    Jan 2018
    Cr7
    Why dont you you put ref of ecu?!!
    Mar 2013
    south africa
    Bosch
    0261204952
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    hi
    if you want use this and report.....
    vito original_ImmoOff.rar
    Mar 2013
    south africa
    Thanks Panathaole I will try and report back. The vehicle is about 60km away so it will be a while before I give you feedback
    Estonia
    Are you try just renew or you want make immo off?
    I have same ecu and looking solution to make immo off.
    Mar 2013
    south africa
    Either one just want it to work. Will try today and report back
    avital's Avatar
    vagimmocalculator.com
    For this exotic ECU BOSCH 0261204952 ,from V-klass 2.8 petrol i mount sometimes emulator.
    Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
    PORSCHE / FERRARI / MASERATI - immobilizer solutions
    VAG IMMO CALCULATOR SOFTWARE
  9. The Following User Says Thank You to avital For This Useful Post:
    raints (29th August, 2018)
  10. #9
    Estonia
    Hi.
    Can you be more specific?
    Which emulator you install?
    Are you modify eeprom dump too after emu install?
    Where you bought this emu?
  11. #10
    I need Immo OFF one of these ECU´s.
    Julie emulator works on this ECU ?
    Someone knows the correct pinout for emulator and what to change in eeprom ?
    Thanks for your help
