Hello
Some one can tell how i can calcul correct pin code for this immobox , i tried use default pin fo M. l200 1999 t0 2003 but doesnt work i need add key by dump or by programmer
Thanks in advance
Cheers
Hi friends
I need help to know what eeprom or MCU i need to read to made new transponder or calcule pin code for M.L200 tracker
Id60
Id61
Annex pic from immobox
Thanks in advance
Cheers
Press "THANKS" button. just one click, CHEERS
Hello
Thanks in advance
Cheers
Hi guys
i need help to solve this car, i already used x100, x100 pad pro i tried add keys but without success, pin code is automatically 3828 but i dont know what´s happend during programm process but key doesn't added successfully because in ECU still immo fault
What tool can do this job without fail, or have any way to add key directly to dump!!
THanks in advance
Cheers
you lost SYnchrone ECU _immo
full dump or
try MUT3
_______________ D3-oToprog _________________
ig : vanos_batam
you have to use sbb or t300 or zedfull
x100 cant add a key
if you can post the eeprom numbers in the immo PCB .. also what is the car MY?
Slem
