Results 1 to 7 of 7
    electrones's Avatar
    Feb 2012
    Around C.V
    Default Mitsubishi L200 tracker immo box
    Hi friends
    I need help to know what eeprom or MCU i need to read to made new transponder or calcule pin code for M.L200 tracker
    Id60
    Id61
    Annex pic from immobox
    Thanks in advance
    Cheers
    Press "THANKS" button. just one click, CHEERS
    electrones's Avatar
    Feb 2012
    Around C.V
    Hello
    Some one can tell how i can calcul correct pin code for this immobox , i tried use default pin fo M. l200 1999 t0 2003 but doesnt work i need add key by dump or by programmer
    Thanks in advance
    Cheers
    electrones's Avatar
    Feb 2012
    Around C.V
    Hi guys
    i need help to solve this car, i already used x100, x100 pad pro i tried add keys but without success, pin code is automatically 3828 but i dont know what´s happend during programm process but key doesn't added successfully because in ECU still immo fault
    What tool can do this job without fail, or have any way to add key directly to dump!!
    THanks in advance
    Cheers
    vanos batam's Avatar
    Jul 2010
    Batam-Indonesia
    you lost SYnchrone ECU _immo
    full dump or
    try MUT3
    _______________ D3-oToprog _________________
    ig : vanos_batam
    Oct 2015
    you have to use sbb or t300 or zedfull
    x100 cant add a key
    electrones's Avatar
    Feb 2012
    Around C.V
    Quote Originally Posted by vanos batam View Post
    full dump or
    try MUT3
    Car lost all key friend, i need add new key
    Cheers
    Quote Originally Posted by Tedum View Post
    x100 cant add a key
    Thanks m8
    Cheers
    Slem's Avatar
    Oct 2015
    if you can post the eeprom numbers in the immo PCB .. also what is the car MY?
    Slem
