only time I seen that happen is when you kill immo in ecu??
u tried putting stock file back on??
Hi guys
Any ideas why on audi A3 2008 after tuning it
the electric windows stopped working ?
If i connect to door modules with vcds i can manually
wind them down and back up.
any ideas anyone ?
does anyone know channel numbers to test switches ?
dave
Tools owned.
AVDI commander.
Dashfixer orig.
Dashfixer clone.
Fiat km tool.
Opel km tool.
Ford KM tool.
Op--com colne.
Lexia & PP clone.
Smok PSA, volvo & ford
If someone helps you DONT FORGET TO SAY THANKS its only polite....
dave11674 (30th June, 2018)
I did immo off in the end as it would not code in properly
i used smok
done many ppd1.2 and the med17 is done the same way
so had to immo off in the end
car runs sweet
but no windows
is there a way to fix ?
ps stock file in donor ecu was same
no windows
orig ecu the eep was messed up when customer tried with gal4 clone
tut tut
Tools owned.
AVDI commander.
Dashfixer orig.
Dashfixer clone.
Fiat km tool.
Opel km tool.
Ford KM tool.
Op--com colne.
Lexia & PP clone.
Anyone know if there is a work around ?
dave
Tools owned.
AVDI commander.
Dashfixer orig.
Dashfixer clone.
Fiat km tool.
Opel km tool.
Ford KM tool.
Op--com colne.
Lexia & PP clone.
no way addapt ecu with GEKO
In 8p audi if immo is not properly working windows are also not working...adapt ecu and get them work again...
Professional BMW immo solutions
Macedonia is one and GREEK!!!
ive adpated many ecu's
this ~~~~er will not get out of SAFE
i know the details are going in cos i read teh eep and flash after and decoded them in smok and all the dash details are in there so match up
i even programmed 2 new transponders into the dash sec block and wrote that back in but still SAFE
dave
Tools owned.
AVDI commander.
Dashfixer orig.
Dashfixer clone.
Fiat km tool.
Opel km tool.
Ford KM tool.
Op--com colne.
Lexia & PP clone.
