Results 1 to 10 of 10
    Dec 2016
    Default BMW 118d Immo OFF need EDC17C02
    Hi i destoyed Ecu of the 118d by touching it with 12V+ from engine start connector.
    I bought new Ecu wuth the same numbers have resoldered Eeprom but still get messeges:
    02E3C DDE: EWS anti-tampering protection
    002E41 DDE: Interface EWS-DDE
    Ista do not want to make DDE EWS synchronistaion shows that this is not possible to do.
    So I need t odo immo OFF. Engine crank but does not start.
    Oryginal flash and EEprom from second (bought) Ecu in atachment.
    Please make an immo off, beacouse this car stays at garage since 4 days....
    P.S. Why Magpro reads EEprom and shows 129KB and Kess reads Eeprom and shows 8Kb?
    EDIT: I have added an EEPROM from CAS 3 maybe someone can addd ISN code do CAS EEPROM?
    should i use then Flash and EEprom from Oryg broken ECU or from new buyied?
    Edit2: I have added file:
    BL IROM GOOD WORKING- thats the oryginal flash file from oryginal ECU
    Edit3:
    Added oryginal EEPROM
    >>Genuine Winols, Swiftec, Ktag, Flex, x17<<
    >Diagnostic, Chiptuning, Dashbord<
  2. The Following User Says Thank You to kubuswujo For This Useful Post:
    impasseborgo (17th December, 2018)
  3. #2
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Immo off in your dreams maybe
  4. The Following User Says Thank You to drugowaz For This Useful Post:
  5. #3
    Dec 2016
    As i saw in other forum, there are people that make Immo Off to edc17c02.
    So it must be possible.
    If not then please add ISN to Cas
    Wysłane z mojego STF-L09 przy użyciu Tapatalka
  6. #4
    neuro's Avatar
    Dec 2010
    UK
    isn transferred from donor ecu.
  7. The Following 2 Users Say Thank You to neuro For This Useful Post:
    impasseborgo (17th December, 2018), kubuswujo (3rd July, 2018)
  8. #5
    Dec 2015
    Slovenija
    HI! Immo off...
    BR!
    Irom drugi sterownik_immo_off.rar
  9. The Following 2 Users Say Thank You to TachomasteR For This Useful Post:
  10. #6
    Jun 2014
    ankara-turkei
    immo off possible ,contact me in mai if not solved
  11. The Following 2 Users Say Thank You to caliskan71 For This Useful Post:
  12. #7
    Jun 2014
    ankara-turkei
    here your off
  13. The Following 2 Users Say Thank You to caliskan71 For This Useful Post:
  14. #8
    Dec 2016
    Immo OFF Working good!
    Thanks!
  15. #9
    Dec 2016
    I have same car in garage but with new ecu, the old ECU that @Tachomaster made IMMO OFF was working good but ecu has dameged for itself while driving.
    Now need one ore time IMMO OFF to adapt new ECU oryg files in atachment
    Thanks in advance!
  16. The Following User Says Thank You to kubuswujo For This Useful Post:
  17. #10
    Mar 2017
    your immo is off already in your file
  18. The Following 2 Users Say Thank You to ZAHEER For This Useful Post:
    impasseborgo (17th December, 2018), kubuswujo (28th November, 2018)
